ksjhawk
Steel Shapes Library
Does anyone know why my Steel Shapes Library is no longer acting as it normally does? Currently, I cannot make a size selection, only 40x999, and all of the steel section objects I've placed read as "Size not found Try new values or see MSA Steel.pdf". I think this started around when I updated my AC28 Library through the updates dialog.
I feel like I need a PhD to manage Global Libraries, Legacy Libraries and Embedded Libraries. I have created wall sections that now have missing steel sections, and the aforementioned text. I spend so much time everytime I need to fix a Library issue, I can't do my real work.
MacBook Pro Apple M4 Max 128GB ram
OS X 15.7.2
AC29 - AC6.5
1 Solution
ksjhawk
I ended up replacing the Archicad Legacy Library and it resolved my issue. Must have corrupted something at some point in that library.
OS X 15.7.2
AC29 - AC6.5
Go to post
ksjhawk
Just realizing maybe this i snot the right place for this...apologies.
OS X 15.7.2
AC29 - AC6.5
ksjhawk
OS X 15.7.2
AC29 - AC6.5
