Find the perfect object, manage libraries, create custom objects
Strange conversion number
Erich
Folks,
Can anyone explain to me why I am getting the strange conversion number (highlighted) in my GDL to get a part to display correctly?
FOR i=0 TO thrdlen*tpi*39.4-1
POLY2_B 7, 3, 6, 91,
shnk/2-H, 0, 1,
-shnk/2+H, -yht, 1,
-shnk/2, -yht-P/2, 1,
-shnk/2+H, -yht-P, 1,
shnk/2-H, -P, 1,
shnk/2, -P/2, 1,
shnk/2-H, 0, 1
ADD2 0, -P
NEXT i
I arrived at this number by measuring the distance the loops was to cover versus the distance it actually did without the conversion. I would understand if it were 25.4 or some similar conversion number, but 39.4 doesn't match anything I would expect. BTW there are no MUL statements or anything similar in the coding.
Can anyone enlighten me?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
4 REPLIES 4
Erika Epstein
39.4 sounds like the inch equivalent of a meter.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
vistasp
Hi Erich,
Erika is right. And if accuracy is important, you could use 39.37 (divide 100cm by 2.54 and you have it.)
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Erich
Thanks, that makes perfect sense and I should have seen it.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
The probable reason for that number is that GDL scripts are always in meters, even if your Project is set to Imperial units. So I guess in some cases numbers need to be converted from meters to inches.
