Surface Label 20 - Split label with identifier
does anyone know how to edit the Surface Label 20 to provide an option to show before or after an identifier? For Example
Full Surface Name in the format code-description, i.e. CT01-300x300 Ceramic Tile Grey
So you could label the surface with the code, the description or both.
code: CT01
description: 300x300 Ceramic Tile Grey
both: CT01-300x300 Ceramic Tile Grey
The only code I have that does this is below, but I can't figure out how to add it to the Surface Label 20.
	!======split
len = STRLEN (string)
iDotPos = STRSTR (string, sep)
code = STRSUB (string, 1, iDotPos - 1)
mat = STRSUB (string, iDotPos+1, len-iDotPos)!material
if display_txt = 'code' and code<>"" then
string=code
endif
if display_txt = 'mat' then
string=mat
endif
Any help with this would be greatly appreciated. The aim of this functionality would let one tag materials like a keynote tool but a lot simpler and more integrated into archicad.
1 REPLY 1
Dukatas
Try using:
string=code + " " + mat
or
string = mat + " " + code
Ben Hruska
ArchiCAD 3.1 - 24
iMac
