ā2005-06-29 11:14 AM
ā2005-06-29 02:33 PM
F. wrote:Hi Frank,
Can anyone help me with the TEVE-command. How do I have to set the "u" and "v" - parameter. Is the origin of the texture related to the x/y/z of this vertex or to the local system?
ā2005-06-29 03:34 PM
There was a discussion about this thread in the old GDL-Talk forum.OK I will have a look on it tonight, when I#m in the near of my archive.
Lubos Cipra, pointed to me the good way.
Attached a short test object, but i did not go further.Thanks. I will give it a try.
BASE ! [... comands to shape the flag] VERT 0,0,0 ! origin VERT 1,0,0 ! X VERT 0,1,0 ! Y VERT 0,0,1 ! Z crI = 1 ! 1st Index crU = 2+256 ! wrapping mode COOR crU, crI,(crI+1),(crI+2),(crI+3) BODY -1 ! ... or 1 or 2 or 4From left to right you see trying it with VERT+EDGE+PGON, MESH and MASS:
ā2005-07-01 08:50 AM
!TEVE Test krychle
width=A
height=B
C=zzyzx
rk=a
rk2=rk*2
rk3=rk*3
rk4=rk*4
DEFINE TEXTURE TX_Kit "krychle", rk*4,rk*3, 2, 0
DEFINE MATERIAL "KitTest" 20, 1, 1, 1,
0.8, 0.74, 0.1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 69, -1,
IND(TEXTURE, TX_Kit)
!if GLOB_FRAME_NR =0 then
!else
! rotx (GLOB_FRAME_NR mod 12 ) *30
!endif
rotx uhel
SET MATERIAL "KitTest"
BASE
TEVE 0, 0, rk, 0, rk2 !#1
TEVE 0, 0, 0, rk, rk2 !#2
TEVE 0, rk, 0, rk, rk !#3
TEVE 0, rk, rk, 0, rk !#4
TEVE rk, 0, 0, rk2, rk2 !#5
TEVE rk, rk, 0,rk2,rk !#6
TEVE rk, rk, rk, rk3, rk !#7
TEVE rk, 0, rk, rk3,rk2 !#8
TEVE 0, 0, rk, rk4, rk2 !#9
TEVE 0, rk,rk, rk4, rk !#10
TEVE 0, 0, rk, rk, rk3 !#11
TEVE rk, 0, rk, rk2, rk3 !#12
TEVE 0, rk, rk, rk, 0 !#13
TEVE rk, rk, rk,rk2, 0 !#14
!souradnice mapovani musi byt taky teve
!coordinate mapped must be too teve
TEVE a, 0, 0 ,0,0 !#15 vektor x
TEVE 0, a, 0 ,0,0 !#16 vektor y
TEVE 0, 0, a ,0,0 !#17 vektor z
TEVE 0,0,0 ,0,0 !#18 bod
COOR 1+1024, 18, 15, 16,17
EDGE 1,2,-1,-1,0 !#1
EDGE 2,3,-1,-1,0 !#2
EDGE 3,4,-1,-1,0 !#3
EDGE 4,1,-1,-1,0 !#4
EDGE 2,5,-1,-1,0 !#5
EDGE 5,6,-1,-1,0 !#6
EDGE 6,3,-1,-1,0 !#7
EDGE 5,8,-1,-1,0 !#8
EDGE 8,7,-1,-1,0 !#9
EDGE 7,6,-1,-1,0 !#10
EDGE 8,9,-1,-1,0 !#11
EDGE 9,10,-1,-1,0 !#12
EDGE 10,7,-1,-1,0 !#13
EDGE 2,11,-1,-1,0 !#14
EDGE 11,12,-1,-1,0 !#15
EDGE 12,5,-1,-1,0 !#16
EDGE 6,14,-1,-1,0 !#17
EDGE 14,13,-1,-1,0 !#18
EDGE 13,3,-1,-1,0 !#19
PGON 4,0,-1,5,6,7 ,-2 !strana 1
PGON 4,0,-1,1,2,3,4 !strana 4
PGON 4,0,-1,8,9,10,-6 !strana 2
PGON 4,0,-1,11,12,13,-9 !strana 3
PGON 4,0,-1,14,15,16,-5 !strana 5
PGON 4,0,-1,-7,17,18,19 !strana 6
BODY -1
ā2005-07-01 11:21 AM
ā2005-09-02 01:11 PM
ā2008-09-11 02:52 PM
ā2008-09-11 03:18 PM
David wrote:David, that's exactly the point.
Most of this discussion from 2005 is way above my pay grade, but am I correct in concluding that the only way to get a texture to correctly map over a very irregular MASS object is to de-construct the object into 3d primitives and use TEVE to define how the texture should be stretched over the surface?
