‎2004-03-25 11:10 AM
‎2004-03-25 12:46 PM
‎2004-03-25 05:04 PM
‎2004-03-29 07:42 PM
rocorona wrote:when I last looked into this the angle was not relative to the prevous point (as in Sweep) but to the start. therefore a square section rotated 90 will look identical to the one not rotated. If you use PUT&GET you can 'accumulate' a changing twist angle as you progress, in a non parametric way you would say,
In the syntax of the command there is the "angle" parameter, that allows for rotating the section along the path...
The angle can be different at each node of the path, but I use the same value.
