Text Rotation in Wall Label
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-11-29 08:09 PM
2007-11-29
08:09 PM
Thanks in advance for your help!
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-11-30 03:44 AM
2007-11-30
03:44 AM
There is a check-box option for text and label text to lock the angle of the text block.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-11-30 03:22 PM
2007-11-30
03:22 PM
erika:
thanks for the response. however, i see no such checkbox. the label i am using is an associative label under the wall tool in the label settings dialogue. the label is set to reference the id of the wall and appear when i check the "label elements" box in the wall settings dialogue. thus far, the label is doing its job nicely aside from the fact that the text within the label won't stay at a fixed rotation of 0-degrees as the wall orientation changes.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-11-30 03:57 PM
2007-11-30
03:57 PM
Labels are a pain to make work right (perhaps my main pet peeve). I have yet to find (or write) a wall tag that places itself properly and remains oriented to the wall. I know I met someone who managed it (for energy calcs) once. I would like to sort this one out.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-12-03 03:10 PM
2007-12-03
03:10 PM
With help from a GDL-savvy friend, I finally made some leeway with the text rotation. It seems that adding the following lines forces the text to stay rotated at 0-degrees regardless of the orientation of the wall. It's a start!
!Add these lines below the label_position lines of the part
if ww = 180 then ww = 0
if ww = 270 then ww = 90
rot2 ww+90
if mir = 1 then rot2 180
!Disable any other wall direction variables
!Add these lines above the STYLE lines of the part
rot2 -ww
Feel free to post any further thoughts or improvements and thanks for your input!
rot2 ww+90
rot2 -ww
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-12-03 04:30 PM
2007-12-03
04:30 PM
Brian wrote:It is assumed that 'ww' and 'mir' are set elsewhere to represent the globals for wall direction and mirroring.
rot2 ww+90
!Add these lines above the STYLE lines of the partTechnically, those ROT transformations just need to be before the TEXT2 statement(s), not the STYLE definition or directive. IMO, it's a good habit to put the transformations near the things you are moving.
rot2 -ww
No nitpicking intended, just wanted to clarify. Looks like you're on your way though.
