Text file input to gdl
Can any one help me with text file input into a GDL program.
I have a text file with one letter in it and that file is sitting in the Arhicad Data Folder. I want to read that one letter and have it as a variable in my GDL program. I have been going round and round in circles by trying to follow information in the GDL help. Thank you in advance for any help.
Archicad V11
Look in the GDL manual for the Text I/O functions. It is toward the end since it is an add-on/extension and not a core part of GDL. The manual can be a bit cryptic at times but it does list all the file handling procedures, commands, etc.
You should also check the other possibilities: one is DATA I/O and I think there is also an XML ability. Maybe that would serve you purpose better.
Just put this in the master script;
ch1=OPEN("TEXT","Mytextfile.txt","SEPARATOR='\t',MODE=RO")
n=INPUT(ch1,1,1,value01, value02, value03, value04, value05)
CLOSE (ch1)
...so it reads a file named "Mytextfile.txt" from your Archicad Data folder.
This example takes in five values from the first row, starting from the first value.
'\t' means that values are separated with a tab which means the same as an Excel file
saved as a 'Tab separated text'.
Hope this helps.
