Texts in my Archicad files are always shown incomplete, like it is slightly cropped.
Abdvlxaziz
Texts are shown incomplete, like an image that has been slightly cropped. I tried look for solutions on the platform but unfortunately, I'm yet to see similar issues. Please check the attached jpeg.
Archicad26
Dell XPS15 9500 | Processor: Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz 2.59 GHz
Installed RAM 32.0 GB (31.8 GB usable)
System type 64-bit operating system, x64-based processor
Pen and Touch support with 10 touch points
1 REPLY 1
Any chance you are on a Windows machine with a high res monitor and have scaled you scree above 100% in the operating system settings?
If so see this post ...
https://community.graphisoft.com/t5/Documentation/Dimension-fonts-not-correctly-aligned-Cut-off-Arch...
It really can help to include details in your signature for your machine specs and operating system as well as the Archicad version and build.
And always make sure you have installed the latest update (build) for the version you are running.
