Textures missing from attributes
Hi everyone, couldn't find any threads on this in particular. I just migrated from 12 to 14. I never used Library 13, so in Library manager I loaded Migration Library 12 and Library 14.
So, in a file that was started in 12, the Library manager gives an error of "missing objects / missing from attributes" and the textures are listed. They are missing from my materials in the 3D window (open GL and Lightworks). The fills are there so elevations and Sketch rendering are OK.
Somehow the textures got detached from the materials? Do I have to go through one-by-one and reassign them in Material Manager?
If anyone knows I would greatly appreciate it! Thanks.
3 Replies 3
Did you assign to the project the ArchiCAD Library 14 folder or only the LCF file?
ztaskai
Migration Libraries are incremental! When migrating from AC12, you'll need Migration Library 12, Migration Library 13 and ArchiCAD Library 14.
I hope that's the only problem...
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
Hey, thank you! I had originally only put the lcf files into Library Manager. When I put the whole folder in, it fixed the problem. That makes sense now, because that is where the textures are. Now I have Migration Lib 12, Migration lib 13, and Library 14 (the whole folder for each) and it works fine.
Thanks again!
