2013-09-27 08:49 PM - last edited on 2023-05-24 11:46 AM by Rubia Torres
2013-09-28 03:52 PM
SimpleTwig wrote:I think you are trying to edit in the 2D View window, rather than the 2D Symbol window. The object is probably using the 2D Script to generate the 2D View, see this thread:
Trying to edit the object under "open object" to change the lines types/pens. When I do this I only have the option of using the selection marquee (even after opening the tools toolbox). How does one use the regular cursor and not the selection cursor?
SimpleTwig wrote:The 2D View has a scale, you may need to enlarge the 2D View window to see and change the scale, it is in the bottom border, similar to the regular 2D Window in ArchiCAD.
Another issue is all of the text is out of scale under the 2D view (even though it appears correct when the object is placed in a document).
2013-09-28 05:03 PM
2013-09-29 03:53 PM
2013-10-11 05:27 PM
