Mac_the_arc
Transfer object parameters to a new object
I often find when creating objects that as I develop the object parameters I find I may decide the there is another object that may be better. Is there a way of transferring some of the basic parameter information to the new object, for instance size (length, height, width), material selection
Operating system used: Mac Intel-based Sonoma
1 Solution
RobPhill33
Yes you can do that, look into transfer element settings.
Go to post
RobPhill33
Lingwisyer
Guru
Are you talking about something like changing from Door to Door with Sidelight? Press Ctrl + Alt when selecting the new object.
OR should this thread be in the GDL sub?
