Learn more
Triangular door frame
Does anybody have any sugestions on how to create a door frame, which will match a custom door panel, with a triangular shaped top?
2 Replies 2
Show the drawing (2D).
Make the whole unit as a custom door. The typical method is to model as slabs and save as a library part from the 3D window (see GDL Reference in your help menu). You will have to edit the symbol since the automatic one is no good. Also, since the unit is non-rectangular, you will also need to include a slab in your model with the ID of "WALLHOLE" to define the wall opening.
