Triple Sash Casement window panes not showing
b_davis
I am modifying a triple sash casement window object.  I can modify the  "Panes Number" in the settings (see image, where each sash is set to 2x2) and it will show me the correct preview for the object in the Settings menu (see settings image preview), but the window itself does not update in the model.  See left side of the image where that same window is selected and not updated.  Nothing seems to adjust this and no panes display in 3d or in elevation view.  They do show in plan view.  How do we fix this?
Plan view shows grids on.  I made them thicker than the glass setting, but no luck.
David Maudlin
b_davis:
Look at Model View Options (MVO) > Detail Level of Door, Window and Skylight Symbols > Window > 3D and Section/Elevation > Full (not Simplified or Schematic).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
b_davis:
David
David -
Thank you so much.  That was exactly the problem.  I appreciate it!
ArchiCAD 28 / Lenovo Laptop - AMD Ryzen 7 5825U with Radeon Graphics (2.00 GHz), 64-bit operating system, x64-based processor
brettwdavis:
Good to know that worked, thanks for adding your signature.
David
Setup info provided by author
