Truck 032 symbol - much to wide
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-05-11 03:07 AM
‎2005-05-11
03:07 AM
This is impossible
Who is the ***** generating these symbols
The way I read to change this would be a snap with Revit but not in AC because there is no width adjustment option, one needs to create a new object, for a novice is not a simple task.
As I have expressed AC is as good as the objects is coming with and this is execrable as this example point out
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-05-12 09:41 AM
‎2005-05-12
09:41 AM
would you post the object, please?
PWD
PWD
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-12-08 09:23 PM
‎2005-12-08
09:23 PM
Yes, I've noticed that also. Truck 01 is the same width (3.824 m!) Probably the lengths are also overdimensioned proportionally (truck 01 is more than 17 m!). And they can't be rescaled, unless you change the scripts.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-12-08 09:57 PM
‎2005-12-08
09:57 PM
That's odd, mine is 10'-3 13/16".
I'm not using the Special Edition Library. Are you? Maybe they changed something in the new library?
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-12-08 10:21 PM
‎2005-12-08
10:21 PM
I'm using the regular Library. Actually I've made a mistake in the previous post. The truck which is 17.324 m long is 'Truck Elev 02'. Anyway, the widths are the same for 'Truck Elev 01' and 'Truck Elev 02': 3.824 m, i.e., 12.54 feet (see attachment).
Which one are you talking about?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-12-08 10:38 PM
‎2005-12-08
10:38 PM
I'm talking about Truck 02.
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-12-08 11:16 PM
‎2005-12-08
11:16 PM
Yes, Truck 02, the one showed in the picture. As you can see, it is 3.824 m wide, or 12.54'.
I just did not understand why your Truck 02 is different from mine.
But the main question is: what is the CORRECT dimension for a truck like that?? I'm working on a Distribution Center, and the preliminary dimensioning depends a lot on this truck's size...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-12-09 08:33 AM
‎2005-12-09
08:33 AM
hi durval,
the correct dimension of such a truck is about 2,50m (width), but measured without exterior mirrors etc.
you should open the library part, correct it and save under a new name.
best regards, gerd
best regards, gerd
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-12-09 03:14 PM
‎2005-12-09
03:14 PM
gerd wrote:Thanks, Gerd, that was what I did.
hi durval,
best regards, gerd
Put a
