Truss MonoPro 10 - Pitch Error
The Truss MonoPro 10 object is not created with a proper pitch that is typed into the Parameters. The Attached Picture shows a Truss this a Specified 8:12 Top Chord, but it is created with a 6:12.
TomWaltz
here's a weird part.... turning on "Jack Truss" seems to fix it
Tom Waltz
So far my workaround is to us the TrussPro 10 and Clip Half of the Truss.
vfrontiers
I was talking to a "Friend" of mine who created the objects a long time ago (ArchiCAD 5.0 or so)....
The JACK TRUSS option should have been corrected to say HIP.. where using this FEATURE, you could type in the normal truss pitch, click ON for HIP and it would adjust the pitch to the correct HIP PITCH required for that roofs normal pitch...
Anyway, I am hoping the switching OFF the JACK (hip) feature would correct your problem. I think the part defaults to ON...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
