Internal error (in binary statement)
Hi All
I keep getting this error message when I am using the marquee in the 3d environment. Any suggestions on how I can make it go away? It happens with every change that I make. Thanks
Number of processor cores : 2
Internal error (in BINARY statement)
at line 16 in the 3D script of file panel door.gsm.
Document name :
Processed : 0 walls 86 objects 0 columns 0 ncBeams
5 slabs 0 meshes 3 pitch roofs
Start time : 2/02/2009 2:38:36 PM
End time : 2/02/2009 2:38:42 PM
Elapsed time : 6 seconds
Projection : Perspective
Eye position : -442.575 265.554 5.39144
Direction : -0.113278 0.983427 -0.14156
Distance : 2.75631 Angle : 60
Start time : 2/02/2009 2:38:42 PM
Elapsed time : 0 seconds
Document name :
Processed : 0 walls 0 objects 0 columns 0 ncBeams
Start time : 2/02/2009 2:38:43 PM
End time : 2/02/2009 2:38:43 PM
8 Replies 8
The BINARY surprises me ... is it possible that 'panel door' is a custom door panel that you created and either did not save as editable GDL, or created it from a 3d dwg?
Karl
Yes, that's right, it's a library part that I created. I usually don't save custom library parts as editable GDL...because I don't know much about the GDL side of things. Should I be doing this as a general rule of thumb?
Thanks!
Hi Olivia,
There is certainly no harm in saving custom parts as editable GDL, so go ahead and save in this format by default. If it still produces an error you can open the object and see which part is not working.
ztaskai
Graphisoft Alumni
Graphisoft Alumni
The 3D checking of ArchiCAD got better for v12 a bit. It can now detect some irregularities in the binaries, too. There is a way to transform old defective binaries into new healthy ones.
  • Place the old object into the project origin of a new project.
    Get an orthogonal 3D top view of it - here you get the errors/warnings about the model.
    Save it as a new binary object.
Normally, this creates a brand new 3D binary.
I'm not sure if it is a solution for your current problem, but I wanted this community to know about it.
Regs,
Zsolt
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
Erika Epstein
Regs,
Zsolt
Great to know; thanks Zsolt. Will this be added to the Wiki and/or put in the tips & tricks section?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
ztaskai
Graphisoft Alumni
Graphisoft Alumni
I'll let the Technical Support know about this issue. I guess they will publish it soon.
Regs,
Zsolt
Zsolt Táskai
Judit Boros
Graphisoft Alumni
Graphisoft Alumni
You can read about this on ArchiCADWiki in the following article:
http://www.archicadwiki.com/Bugs/3D%20error%20message%20possible%20binary%20bug
Judit Boros
Technical Support Team
Budapest, Hungary
archicadwiki - the ArchiCAD knowledge base
I keep getting that same message. but it will not even let me view it in 3d at all. it just keeps saying the same error. then nothing shows.
any suggestions??
