Truss Struts
I've been working with the struts in the AC 9 Roof Maker library 81(Strut12_1..Strut22_1). What I'd like to do is script them so that the upper end of them has a perpendicular cut rather than plumb or level(vertical or horizontal). This cut must remain regardless of the pitch. The bottom cut can remain as it is. I assume it has to do with the "Sin..Cos..Tan" formulas but I can't isolate the ones I need to create the perpendicular cut. Thanks in advance. Doug
11 Replies 11
Impressive menu.
Thanks,
Peter Devlin
Rod Jurich
Peter wrote:
Impressive menu.
It's amazing sometimes where threads lead. I asked myself "what menu" before reading earlier posts.
Many thanks for your geomerty, Peter.
Rod Jurich
