2006-02-03 10:06 PM
2006-02-04 02:26 PM
Jay wrote:
Using the TrussPro Object with a Scissor Chord the 3D view has a "full-panel" when viewing it it on direction. it is okay viewing it in the other direction.
2006-02-04 04:25 PM
2006-02-04 04:28 PM
2006-02-04 07:29 PM
Jay wrote:Jay:
Only selecting one Truss and viewing with the Open GL Engine results are a little better. The truss is not partially wireframe and the Scissor can be seen regardless of direct of view. there is no shading though?
Can any one else confirm this?
2006-02-05 02:29 AM
2006-02-05 03:03 AM
2006-02-05 03:20 PM
Jay wrote:
The Trusses have a 8 41/64" Heel Height because that is the True height of trusses that are manufactured (given a 2x8 top chord which is 1/4" raise off the bearing).
If the Truss Heel height is set to zero the problem does not occur. I guess I will just have to add the raised top chord dimension (1/4") to the over all top chord dimension. Which means adding 0.289425" to the depth of a top chord that has a 7:12 pitch.
