2006-06-12 09:12 AM
2006-06-12 09:36 AM
David wrote:This has been true for every ArchiCAD upgrade that I can recall with the sole exception of the transition from 6.5 to 7.0. It is for this reason that there is a warning whenever you open an older part in a newer version of the program. It is good to point out though since it is a serious pain if you have to recreate an old part from one that has been saved to a newer version.
Any GDL element that has been edited and saved in 10 will no longer open in 9.
2006-06-13 06:09 AM
2006-06-13 08:16 AM
2006-06-13 08:22 AM
Matthew wrote:This is true for older objects, I've found, but library parts created in 9.0 will not give fair warning when edited and saved in 10.0.
.... there is a warning whenever you open an older part in a newer version of the program....
2006-06-13 08:57 AM
David wrote:Strange. It's been working for me.Matthew wrote:This is true for older objects, I've found, but library parts created in 9.0 will not give fair warning when edited and saved in 10.0.
(guess how I found that out )
2006-06-13 09:27 AM
F. wrote:are we supposed to know about that? I feel like I should be keeping an eye out for some sinister looking East Europeans for the next few days ....
1. Use the "Black Turtle" ...
2006-06-13 09:33 AM
2006-06-14 07:05 AM
Matthew wrote:Very strange. I've just tested it again. Objects created in 9, then edited in 10 are saved without a warning message and then can no longer even be seen as a library part in 9. "Open object" error message in 9 reads "Unknown Document Version."
2006-06-14 08:12 AM
David wrote:The very odd bit is that I occasionally get that message when I try to open parts in AC9 that I have NOT saved in AC10. This happened earlier today with a part that I had just written from scratch in 9. I saved and closed the part, and then later went back to edit it and it refused to open with the "Unknown Document Version" message. I did get it to work eventually but now I don't remember how - I think it opened in a different session.Matthew wrote:Very strange. I've just tested it again. Objects created in 9, then edited in 10 are saved without a warning message and then can no longer even be seen as a library part in 9. "Open object" error message in 9 reads "Unknown Document Version."
