Learn more
Two panel stacking door?/bifold
I need to show a double panel french door that stacks to one side. Can anybody help me.
1 Reply 1
It sounds like you're referring to a bipass or sliding door...If you are, the closet thing in the standard library will be one of the sliding doors in the "special doors" folder of the library. Unfortunately, these are treated as glass sliding doors and don't have the panel options you might be looking for...you can, however, apply a material to make the glass look/read opaque.
don't know if this answers your question but hope it helps
Dan K
