U.S. modules
Is there U.S. modules for archicad 10? (bathroom, ada, kitchen, bedroom,) Do they need to be downloaded?
3 Replies 3
Link
They were taken out of the program in version 10, and AFAIK there's nowhere to download them. They may be no longer supported?
You could always use the ones from 9 if you still have it loaded somehwere.
Link.
If I use US modules version 9 then I have to substitute all library parts (that will turn into dots on version 10) to its corresponding parts on 10?
This is a lot of work...
I think there is an Archicad 9 library subset available for Archicad 10. You should get it and load it with your libraries. Then it should work, you would keep using AC9 library parts in AC10.
