UK "One Way"Road Sign
fuzzytnth3
Has anyone come across an Object or objects that is like this?
tia
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Erwin Edel
Maybe something you can customise to look like it by getting this library? https://bimcomponents.com/LCF/Details/819
You could get one of the posts from that library (by changing to morph) and combine it with the picture frame object with that image file to get something to look like it. Or if it is wall mounted, just use the picture frame object.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
fuzzytnth3
Sadly that Library does not have that sign. I have that Library already and was hoping someone had made one already to save me the bother.
Looks like I will have to do it myself then
Erwin Edel
Ah sorry, if I was unclear: I mean place one of the wrong road signs, convert to morph, delete the unwanted sign, keep the post and use the picture frame object from the library with the image file you put in your post. Combine it with the morph and you have a similar solution, right? You can save it as an object after that if you want
Should take at most 5 minutes, I would say
www.leloup.nl
Windows 10 Pro
