Archi7
Update loaded library?
How do I get texture images for the materials in my library? Im new with all these.
1 Reply 1
What does you Library manager say?
It should list all of the "missing" texture files and if you select them in the list, it should say where they are missing from.
This may give you a clue as to the library you need to load.
Attach a screen shot of your Library Manager and I can point you in the right direction.
Paste the image directly into the text as you type rather than using the 'drag & drop here' box below.
