Use of real types...
Dave Seabury
I am writing a script for a roof truss. I have to test for three conditions at the heel. For one of the conditions I am testing for zero ie IF heel_height - bottom_cord_height - plumb_cut_topcord = 0 THEN............ but i keep getting a warning "use of real types can result in precision problems"
Is there a way to get around this warning? Is testing for zero what causes it?
Thanks in advance
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
5 REPLIES 5
vistasp
David, try:
IF heel_height - bottom_cord_height - plumb_cut_topcord < 0.0001 THEN...
A better option, especially if you're going to test this condition multiple times, would be:
Master Script:
EPS = 0.0001
2D/3D scripts:
IF heel_height - bottom_cord_height - plumb_cut_topcord < EPS THEN...
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
You might want to make this ... IF ABS(heel_height - bottom_cord_height - plumb_cut_topcord) < 0.0001 THEN...
Just in case you do have the situation where you might have a negative value.
Otherwise any negative value will be less than the tollerence and will trigger the condition.
The other way is to change the value to string and check if the string ="0" (if the STR parameters set to put 1 character)
If the object has some predefined heights/lenghts/whatever it is kind of useful.
But if the only one thingy is checked - the mentioned before solutions are better.
Best Regards,
Piotr
Dave Seabury
Piotr, Barry and Vistasp,
Thanks for the insight and suggestions, I will try these and see if i can get to run as i think it should.
Thanks
