Value list for arrayed parameters
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-06-25
05:20 AM
2023-05-24
11:57 AM
Rubia Torres
VALUES "param_name" "value_1', "value_2", ......
But is it possible to set a value list for an arrayed parameter?
Something like ...
VALUES "param_name [1][1]" "value_1', "value_2", ......
I have a window that has a variable number of horizontal and vertical panels.
Each of these panels can be fixed (F), awning (A) or louvre (L).
At the moment I have each panel listed with a separate parameter as that is the only way I can get the value list to work.
Am I overlooking something obvious or can it not be done?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-25 06:18 AM
if you are just wanting to set the values for the parameter array, then just click the array button next to the parameter you are setting up? if that makes sense.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-25 06:23 AM
sdb wrote:I want to give the user a list of values to choose from.
Hi
Just as you can with a standard parameter.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-25 01:08 PM
Barry wrote:I don't think it is possible.
Something like ...
I would use hotspots to make a three positions switch.
Easy way to graphically change the types of window, in 3D or 2D.
dim windowType[] dMin = -0.15 ! for example dMax = 0.15 for k = 1 to nb dist= min (max (dMin, dist ), dMax) if dist < dMin / 2 then dist = dMin windowType = 'A' else if dist < dMax / 2 then dist = 0.00 windowType = 'F' else dist = dMax windowType = 'L' endif endif next k parameters dist = dist
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-25 03:23 PM
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-26 05:41 AM
Olivier wrote:Thanks Oliver.
This is exactly what I am doing.
The thing is my window can have anything from 1 to 6 panels horizontally and 1 to 6 panels vertical.
So anything from 1 to 36 panels and each can be set to awning, louvre or fixed individually.
So I was hoping arrays could help.
I am using arrays for the frame positioning but it seems it is not possible for the frame type.
It can still be done - I just need to repeat the script 36 times!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-26 05:42 AM
rocorona wrote:That's what I expected.
Nice, but not possible (yet)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-28 08:27 PM
VALUES "fx" "Festverglast",
"Drehkipp links",
"Drehkipp rechts",
"Dreh links"
Then you have to use the User Interface to have single Value lists. The normal parameter list cannot do this, as the other users wrote.
Use something like this:
led=24
FOR k=1 TO 18
UI_INFIELD{2} fx
dy=dy+led
NEXT k
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-29 08:19 PM
Joachim wrote:Guten tag Joachim,
If I understand you right, you want to use the same 3 values for every parameter. This is possible only in the User Interface; say fx is an array parrameter:
"Drehkipp links",
"Drehkipp rechts",
"Dreh links"
led=24
FOR k=1 TO 18
UI_INFIELD{2} fx, 185,dy-4,100,16
dy=dy+led
NEXT k
Thanks for this nice workaround! I completly missed this possibilty.
You are right, UI allows to do this with just one parameter.
In the attached example, I just added a User Interface.
Mixed (or not) with "Hotspots Switch", it can be an interesting solution.
Thanks again.
Olivier
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-29 10:36 PM
Here's another, a floating tooltip with textual content.
!--values values 'a' 0.5, 0.75, 1 if a<0.75 then parameters tip[1]= '[LEFT] middle right' if a=0.75 then parameters tip[1]= 'left [MIDDLE] right' if a>0.75 then parameters tip[1]= 'left middle [RIGHT]' !-- !--2D hotspot2 0, 0 line2 0, 0, a, 0 hotspot2 0, 0, uid+1, a, 1 hotspot2 -1, 0, uid+2, a, 3 hotspot2 a, 0, uid+3, a, 2, tip[1] uid= uid+3 !--
Regards, Juha
