2005-10-31 07:52 AM - last edited on 2023-05-24 12:48 PM by Rubia Torres
2005-10-31 10:42 AM
2005-10-31 09:59 PM
Graeme wrote:two things to check:
I forgot to mention that they only vanish when I import the plans into Plotmaker. They are there in AC but do not show in PM. Very Strange.
2005-10-31 11:31 PM
2005-11-01 12:09 AM
2005-11-01 04:06 AM
Graeme wrote:this is normally only an issue when you are using a different computer on the same network to perform the plotmaker updates: BGarchiCAD on the plotmaker machine tries to resolve a file path somewhere on the local disk of the archiCAD machine that it doesn't have access to . . . maybe not applicable in your case.
Unfortunatley Ben I dont know how to ensure that background AC loads the right libraries. Please advise if you may. I also tried reimporting the layout but that didnt work.
With some tinkering I found that the window and door layers in PM were hidden??????? I thought when a view was imported to PM it brought the attributes of the layout with it???only when the update rules (as you have correctly surmised) are set to overwrite any changes you may have made in plotmaker with the archiCAD view attributes.
Anyway to fix the problem I found I had to take the following steps in PM:this could actually be a bug: what you're saying is that archiCAD's view attributes
Navigator/Settings/Attribute Update Rules/Custom For the Drawing/ Untick Layers/Attributes/Edit Layers/Show Windows and Doors and Wall Layers that are hidden or partially hidden.
2006-04-11 05:35 PM
Graeme Barr wrote:I seem to be having this problem. I trieed to go into BGarchiCAD to update the libraries but the Libraries Manager is greyed out. How do I direct it to the right library?
2006-04-13 03:26 PM
