Lingwisyer
Guru
Variable within Text
Hi all,
Figured this would similar to how it is in excel and basic but I can't figure out how to do it...
1. How do you insert a variable into a text string? eg. "1:variable_x @ A1"
2. How can you insert a text string at the end of a calculation? eg. variable_y=variable_x*5 "outlets"
Ling.
1 Solution
If variable_x is a string value then you can just concatenate (add) them together.
"1:" + variable_x + "@ A1"
If variable_x is a numeric value then you have to convert it to a string.
"1: " + STR(variable_x,2,0) + " @ A1"
variable_y must be a string variable of course.
Then same as before if variable_x is a string value then you can just concatenate (add) them together.
variable_y = variable_x + "*5 outlets"
variable_y = STR(variable_x,2,0) + "*5 outlets"
Or if you actually want to multiplt variable_x * 5 then
variable_y = STR(variable_x*5,2,0) + " outlets"
Go to post
1 Reply 1
