Victorian railings
Alex Smith
Has anyone got a railing that resembles those on a victorian terrace?
12 REPLIES 12
Dwight
like this?
Dwight Atkinson
Alex Smith
Actually its more like this (see photo attached)
Dwight
Oh. Invisible.
Dwight Atkinson
Alex Smith
cant seem to get the photo to attach
Dwight
Mime it then.
Dwight Atkinson
Dwight
There are two ways to make ornate ironwork.
Use the complex profile to describe a railing module. Use it in a wall, but perpendicular to the railing direction - this gets the depth of the ironwork.
Multiply the modules along.
The other way is when you have complex smithing - hammered leaves and whatnot. Use a masked picture to knockout the background for transparency in the rendering.
Dwight Atkinson
Alex Smith
can u see this?
Dwight
Yes.
I doubt if there's a pre-made object this detailed.
It is easy to model this with the complex profile method if you have the orthographic drawing, however, there will be many polygons. How much do you need to make?
You could do it with two depths.
Dwight Atkinson
Alex Smith
Thanks Dwight - It seems a bit too hard
