View Objects on all relevant stories
Josh Verran
When placing objects, I have tried using the show on stories "all relevant stories" option, however, it is hit and miss as to which objects this actually works on.
What's happening here and how can you tell which objects this will work on and which ones it won't?
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER | LinkedIn | My Top Wishes
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Perth, Australia and Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
vdentello
It has to do with object's actual ZZYZX (native height) parameter, whether it crosses the story threshold or not.
I did a test where i placed a cube with the "all relevant stories" option set and it'll only show on the upper story when its placement height+height make it cross the upper story line. Same for stories below.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
runxel
Legend
Also depends on the fact if "ac_bottomlevel" and "ac_toplevel" are set correctly in the GDL-object.
Both parameters are usually hidden from users sight.
If "ac_bottomlevel" is higher than the toplevel the "show on all relevant stories" option will definitely not work.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
