View Objects on all relevant stories
When placing objects, I have tried using the show on stories "all relevant stories" option, however, it is hit and miss as to which objects this actually works on.
What's happening here and how can you tell which objects this will work on and which ones it won't?
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
2 Replies 2
vdentello
It has to do with object's actual ZZYZX (native height) parameter, whether it crosses the story threshold or not.
I did a test where i placed a cube with the "all relevant stories" option set and it'll only show on the upper story when its placement height+height make it cross the upper story line. Same for stories below.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
runxel
Also depends on the fact if "ac_bottomlevel" and "ac_toplevel" are set correctly in the GDL-object.
Both parameters are usually hidden from users sight.
If "ac_bottomlevel" is higher than the toplevel the "show on all relevant stories" option will definitely not work.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
