‎2010-10-01 10:12 PM
‎2010-10-03 04:07 AM
‎2010-10-03 11:25 AM
‎2010-10-03 11:45 AM
‎2010-10-03 07:26 PM
‎2010-10-03 09:30 PM
Diana wrote:My preference is to export as 3DS from SketchUp and use the add-on to convert these to library parts. I find it produces much superior results for minimally parametric elements (like furniture) but does require using SketchUp Pro.
Thank you for your answer.
Correct me if I am wrong, but to import a Sketchup model into ArchiCAD, this plugin is needed:
http://www.graphisoft.com/products/archicad/addons/google_earth/
For the moment, only 32bit version is available😞
‎2010-10-05 12:08 AM
Joachim wrote:Amazing!! Thank you!!!
http://www.vis2real.de/
and
http://www.winhard.de/deutsch/gdl/gdlsamples.html
Matthew wrote:All right, I will try then
‎2010-11-29 03:23 PM
‎2010-12-02 09:45 AM
Diana wrote:OBJ (wavefront) is "similar" to 3DS, so your best to just import the 3DS models, watch out though as the poly count will be high!
Fritz Hansen download section:
http://www.fritzhansen.com/en/fritz-hansen/products/product-library.aspx
Can OBJ objects be imported into ArchiCAD?
Thank you!!🙂
‎2010-12-02 01:05 PM
sdb wrote:I see. Thank you!
