‎2017-09-25 02:55 PM
‎2017-09-25 03:03 PM
‎2017-09-25 05:38 PM
‎2017-09-29 03:35 PM
Piotr wrote:I shall look into working with 'cutpoly'. What is the best way to create curved surfaces, obviously WC's are not square. ?
The seo is the worst decision - performance wise.
The cutpoly etc is far better, but direct modeling is the fastest.
I made a test doing this:https://bimobject.com/en-us/komandor/product/komandorunipanels
The perforated panels when doing the perforation with SEO were unusable...cutpoly better, but the holes made in prism definition were the fastest.
Best Regards,
Piotr
‎2017-09-29 07:13 PM
‎2017-10-02 03:03 PM
Piotr wrote:Thanks for the help. The main issue I am having is actually modelling the object with accurate curves. The morph tool is clearly the best option for modelling, but it seems as though there is no easy way to create accurate curves that aren't using the revolve tool. The revolve tool doesn't give me what I want so I can't use it.
You can save the morph to gdl.
The object will be bigger but performing better than the morph itself.
If You wish to have a small object with nurbs inside to get either slow or fast object in one - the fastest way is to import the nurbs from Rhino. (AC>=20)
Best Regards,
Piotr
‎2017-10-02 11:04 PM
‎2017-10-03 09:39 AM
‎2017-10-03 11:31 AM
Barry wrote:This is a basin that i'm currently working on. Same thing applies, I can't work out the correct method of using the morph tool to produce the best results.
It just depends how accurate you want to be.
The attached image is just MULed cones, cylinders and prisms.
If you want something a little more realistic then yes MORPHs are the way to go.
Or go to 3D Warehouse or other model sites and import one of those.
You can even find some in native Archicad GDL objects.
https://specify.caroma.com.au/bim-library-landing/archicad
Or model in other software that is better at doing this type of thing and import them in.
‎2017-10-03 11:44 AM
