JGoode
WC object.
I am trying to create a WC object (or a few of them). I cannot figure out the best way to create it. The main issue is the actual bowl of the WC. Is using SEO's the way to go? Due to the curves of the WC it makes it tricky? What is the best way of creating this object? Complete GDL, model using morphs/slabs/etc? Any guidance is appreciated. It doesn't need to be parametric it just needs to look better than average and have a relatively low polycount. Thanks very much.
ArchiCAD 27
Windows 10
15 Replies 15
JGoode
Barry wrote:
That looks pretty good to me.
The morph tool is not that easy to use for things like this.
If symmetrical I often model half, mirror a copy and combine.
More often than not I find a 3D model, import it and turn it into a morph, clean it up if necessary then save as an object.
The Caroma objects are quite good and in fact they have used a lot of REVOLVE commands from memory.
The problem is the polycount, which is over 2000, which is just way to high for something that will be used several times in a project. I don't know if it would be possible to produce similar results with a lower polycount. All of the objects that I need are downloadable as gsm's from the manufacturers website but they are just too high poly.
ArchiCAD 27
Windows 10
David Maudlin
If the Object is converted to Morph, use the Morph command Modify Segmentation > Fewer Segments to get to the sweet spot between appearance and polygon count.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
JGoode
David
Where can I find the Modify Segmentation command?
edit: Found it. What an excellent tip. I never knew it existed. It has made my life much much easier Thanks very much
ArchiCAD 27
Windows 10
Use the modify segmentation with caution.
There will be a point when it will reduce by only a few polygons but will give you an unsatisfactory 3D model.
Always keep a copy of a morph before you edit it - sometimes it is much easier to start again than to try and undo what went wrong.
Don't worry about the 2000 polygon count too much.
Even the basin attached which is one REVOLVE command only with RESOL of 36 has over 1500 polygons.
This is the same bowl converted to a morph.
Same polygon count (1586).
The one on the right was modified with fewer segments.
Only reduced it by 140 polygons but as you can see the 3D is already corrupting.
JGoode
I've noticed the drop in quality of object. I have managed to maintain close to the same quality of object with half the amount of polygons. Seems to have worked a treat for me so far.
ArchiCAD 27
Windows 10
