WINDOWS AND DOORS SEEN IN 3D MODEL BUT NOT PLAN
What settings or ... would be causing windows and doors to only appear in the 3D model and not the floor plan. I can place a door or window but do not see the symbol once placed only see it in elevation in the the model, suggestions, thank you????
Working in ArchiCAD V.12 on a MAC
6 Replies 6
Check that you Model View Option is set to "Show on Plans"
Where do I find the Model View Options box?
That was a good suggestion but the box "show on plans" is checked on both windows and doors.
So now what should I do ?
THANK YOU
See if you have the 2D display option for the windows/doors set to 'symbolic' - they will then ignore the Floor Plan Cut Plane (FPCP) and will likely appear. Alternatively, change the cut plane height...
Karl where do I locate the 2D display option?
Srinivas
What Karl means is the floor plan display of the window in the Window settings dialog box.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
