WOOD FENCE 17??...WHY ONLY 6'-0" MAX
rob2218
see
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
9 REPLIES 9
rob2218
this wood fence object is a great tool.....but...if I can't make it a height I need..then what good is it?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
have any others tried this object? Can anyone else get it to get taller than 6'-0"? if so, please.....how did you do it?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Interesting object. I hadn't noticed it before.
For some reason, the parameters are explicitly limited to 6' in height. You can edit the Parameter script by selecting a placed object, doing an Open Object and editing as shown in the attached. (Or similar - I just put a 1 in front of the 6 to make the height limit be 16'.] Save with a new name in your embedded library.
For the board on board that you show, this seems to still work fine. Get a few weird results with some other panel types after the above quickie mod, but probably good enough for what you want.
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
rob2218
Karl,
anyway I can get you to send/email or post up that new "fence" file?
I can't seem to make mine work.
I change the settings you show...then say "save" as an embedded object and it doesn't allow me to alter the parameters to the taller fence....
thanks
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
nevermind...I'm an idiot.
didn't follow your diagram and only changed one parameter and not the other...but now changed the other so now it works...thank you.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
Are you sure it's not being limited by your H.O.A. ?
Marc Corney, Architect
Red Canoe Architecture, P. A.
rob2218
humm.....you may have stumbled on to something sir..............Now I get it...that's the cause of all of AC's crazy programming...the dreaded H.O.A.
And we thought the NSA was bad......sheesh.....
Look out neighbors of the world...........H.O.A. is a comin' to get YOU!
i>u
Edgewater, FL!
SOFTWARE VERSION:
jbArch
Found this thread because I'm having same problem with the AC19 part. Except mine will only go to 4'-10" height.
I tried editing the part as Karl suggested (the parameters in the object actually show 6' as upper end of height range), but this seems to have no effect.
Any tips?
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
Aaron Bourgoin
evidently, there are some bugs that didn't all get fixed during the AC19 beta testing.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.26 Mac
MacOS Tahoe 26.2
