Wainscot Feature - AC Wall Accessory or OOL Object?
Does anyone have an opinion regarding the suitability of AC molding and wainscot wall accessory? I know it is a "goodie" that is no longer supported by AC. I noticed that Objects On Line sells a similar part. Any thoughts or suggestions greatly appreciated.
3 Replies 3
MMontgomery
Try complex wall profiles?
AC 6-30 - Ryzen9 9950X / 96GB RAM / RTX 5090 / Win 11 Pro Claude-Tapir-Archicad
Erika Epstein
I've had a lot of problems with the add-on, specifically corner conditions aren't always correct and not fixable when some corners are inside and others outside as when you have an L shaped room.
Use the custom profile tool instead to add trims to your walls as suggested.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Many thanks for the input/advice. As usual, very helpful and timely!
