Wall Accessories Not in Library
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-12-04 09:09 PM
2018-12-04
09:09 PM
So, I just was hoping someone could explain how to get the Wall Accessories tool to work so I can use the wall framing tool.
>ArchiCAD 23, 7000 USA FULL
>iMac, 27-inch, 2020, Processor: 3.8 GHz 8-Core Intel Core i7, Memory: 64 GB 2667 MHz DDR4, Graphics: AMD Radeon Pro 5500 XT 8 GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-12-05 02:58 AM
2018-12-05
02:58 AM
Just Double Checking as You probably have already done this?
Even though you installed the goodies, the Accessories Library was not installed. You'll find it in the Archicad Library and is the Accessories Library.lcf file, It must be loaded via the Library Manager, Then the wall Accessories tool will work under design extras.
BTW-- this tool is extremely buggy and generally does not work with complex profile walls with internal connections.
Been reported but response was that its not likely to be fixed. Version 19 seemed to work best but has just gotten more buggy with seceding versions. Unfortunate that Graphisoft does not have a reliable wall framing tool.
Gerry
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-12-05 05:29 PM
2018-12-05
05:29 PM
Thanks. I was picking the wrong file name.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-12-05 06:34 PM
2018-12-05
06:34 PM
I'm not seeing any info in the Wall Accessories in the ArchiCAD PDF Instructions, but I'm having trouble with the wall framing tool. The bottom plate turns up and almost touches the top plate before it turns to horizontal for a few inches. The end studs still show up, but they are in the space between the bottom and top plate, which is only a few inches.
I don't know how to stop the bottom plate from turning up. I thought I tried all possible setting combinations too.
The framing tool only seems to work when I have "Use Wall Bottom Edge" selected.
