I'm not seeing any info in the Wall Accessories in the ArchiCAD PDF Instructions, but I'm having trouble with the wall framing tool. The bottom plate turns up and almost touches the top plate before it turns to horizontal for a few inches. The end studs still show up, but they are in the space between the bottom and top plate, which is only a few inches.
I don't know how to stop the bottom plate from turning up. I thought I tried all possible setting combinations too.
The framing tool only seems to work when I have "Use Wall Bottom Edge" selected.
>ArchiCAD 23, 7000 USA FULL
>iMac, 27-inch, 2020, Processor: 3.8 GHz 8-Core Intel Core i7, Memory: 64 GB 2667 MHz DDR4, Graphics: AMD Radeon Pro 5500 XT 8 GB
