Srinivas
Wall Contours
I am new to Door - Window Builder ( V 3.5) from CAD Image and having some problem with the wall contours as in the attachment.
Can someone pull me out of this as I am unable to find out how to get the wall contours displayed correctly.
Also How to make certain settings as default for example:-
1) I want the Threshold to be switched off everytime.
2) Measure Reveal Exterior also to be off.
Thanks in Advance.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
3 Replies 3
There is usually a parameter called Wall Contours. It controls the visibility of those missing lines. Its possible values are usually between 0 and 3.
__archiben
laszlonagy wrote:
There is usually a parameter called Wall Contours...
it can be found under the Symbol>Plan View Items settings (see attached - you may have to 'Show more options' to get it to appear)
HTH
~/archiben
b e n _ f r o s t
Laura Yanoviak
You can do this by creating a Default File of the settings you want saved (see the DWB User's Guide).
