Wall Depth Variable in Archicad 12
The wall depth variable in versions 11 and before is C_. Has this changed in version 12? My custom doors that worked in 11 and before are sticking out from the wall (photo below - The fireplace shown below is actually a "door" object).
Thanks in advance for any useful help.
8 REPLIES 8
Erich
Masterscript,
The Old Global Variable C_ should still work. It is listed in the GDL Reference Guide anyway. What happens if you replace it with the new variable WALL_THICKNESS?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
I will try the new variable and see what happens.
Thanks.
Erich
It shouldn't matter. I realized after my first post that I have doors and other objects written both ways that I use in 12. There is an offset parameter. Could that be set to a non-zero value?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
I changed the Reveal Depth (under the Reveal tab) to 0", and it fixed the problem.
Erich
That would be the offset I was thinking about. Glad it worked.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Thanks for the lead. Glad it was an easy fix.
ztaskai
Graphisoft Alumni
Graphisoft Alumni
Just a quick comment. From AC12 on, you can set the reveal/sill depth from your parameter script. On top of that, you can control whether the old-school reveal parameters should be available or not. Refer to the '2.2. Door/Window objects' section of Appendix 'Fix named optional parameters' of the Basic Library Documentation. Start browsing from here: http://www.graphisoft.com/support/developer/documentation/LibraryDevKit/
Using this you can force the sill depth of your object to 0 if it is not ready for an actual sill depth.
Regards,
Zsolt
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
Thanks for the tip.
