felcunha
Wall accessory don't get the material of the wall attached ?
We're trying to create an wall accessory that shows the surface (material) of one face of the wall. Unfortunately it only shows the replaced surfaces, even when they are NOT activated !
We're using ac_left_mat and ac_right_mat to get the surfaces, but none of these inform the accessory about the original surface of the face when it's not replaced...
Could you help us ? Would you have a solution or a workaround ?
Thank you in advance !
Felipe Ribeiro Cunha
AC 26, macOS Monterey
2 Replies 2
I think you are looking for "WALL_MAT_A" and "WALL_MAT_B".
felcunha
No. I may be wrong but I think I can't get a wall property "WALL_MAT_A" or "B" from a wall and put it into a wall accessory...
Anyway I couldn't find how...
Any help ?
