We value your input!
Wall accessory don't get the material of the wall attached ?
felcunha
We're trying to create an wall accessory that shows the surface (material) of one face of the wall. Unfortunately it only shows the replaced surfaces, even when they are NOT activated !
We're using ac_left_mat and ac_right_mat to get the surfaces, but none of these inform the accessory about the original surface of the face when it's not replaced...
Could you help us ? Would you have a solution or a workaround ?
Thank you in advance !
Felipe Ribeiro Cunha
AC 26, macOS Monterey
I think you are looking for "WALL_MAT_A" and "WALL_MAT_B".
felcunha
No. I may be wrong but I think I can't get a wall property "WALL_MAT_A" or "B" from a wall and put it into a wall accessory...
Anyway I couldn't find how...
Any help ?
