Wall label that displays composite wall name
Hi Folks,
We are creating a bunch of composite walls named their partition type(1, 2, 2A, etc.) And I'm trying to get my wall label to display the name of the composite wall.
I'm using a request to get the name to display in the text, but its not working yet. I'm concerned I'm missing some parameter function. Care to weigh-in?
Thanks.
My script follows:
! Find Wall type name (WTN ) from Composite wall
wall_typ_name=""
Request ('WALL_COMPS_NAME', '', wall_typ_name)
TEXT2 0, 0, wall_typ_name
I thought the text2 command would display the requested value, but it isn't doing anything.
4 REPLIES 4
Try:
wall_typ_name=""
n1 = Request ('WALL_COMPS_NAME', '', wall_typ_name)
I didn't test it but I think it should work.
HTH.
Hi Paulo,
Thanks, but no luck.
I get the message, "Unused function return value" and then describes wall_typ_name as an "uninitialized variable." The script stops. ( I know it stops, because there are lines and text that aren't showing up in the 2d full view with the request code. ) Strange, because I thought it would just return a "0" value, and continue.
Other suggestions?
Hi Nathan,
Sorry. Yesterday I was just leaving the office when I answered your post...
I've checked the GDL Reference Manual this morning. 'WALL_COMPS_NAME' is not a request, but a global variable for walls... Try this on the 2d script:
TEXT2 0, 0, WALL_COMPS_NAME
This time it will work.
Thanks. Did the trick. As usual, making things more complicated than they need to be.
-Nathan
