Wall lamp 16 - appearance
when using wall lamp 16 the 2d representation of the lamp is 90 degrees off from the 3d orientation or vice-versa, so the 2d plan of it cant be used if you want it correct in 3d. is this a bug in AC16?
1 REPLY 1
David Maudlin
simonblencowe:
The object in the US library is ok, you could try downloading the object from bimcomponents.com site, maybe the object in your library has a bug.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
