We want a bigger and updated Parameter Array Sub Window?
Nader Belal
Mentor
Hi everyone,
I'm proposing that Graphisoft team would renovate the Parameter Array window in the GDL Editor ?
The one that we have right now is like Graphisoft have just forgot to improve (it almost feels prehistoric)
I'm proposing the following improvement:
1. Make that Parameter Array window resizeable to be bigger than it's actual size (an advantage to have a bigger view of the array).
2. Add/Delete/Edit Parameter Array Values from with in the array table, instead of using the cell field side-kick.
3.Add the feature that we can select all array cells with in the Parameter Array window and paste its values to a text file, similar to what we can do in spreadsheets programs.
Thank you
0 REPLIES 0
