Where did my library and hatches go?
Hey y'all...
I'd loaded AC10 on my Dell about a year ago. I quit using it in October, and hadn't started it until today. And now my libraries are gone, and I only seem to have one fill pattern / hatch.
And my composite wall setup has gone funny (tho it looks OK in the drawing... the representation in the setup window is all screwed up).
Should I expect buggy operation after such a long hiatus? or with a different key?
Should I just reinstall the software?
Thanks.
AC10; WinXP Media
6 REPLIES 6
Ok, I found my library.
But my fills are still missing (?!?)
__archiben
they are contained in the file itself. either open up an old project and then File>New...>Use Latest Project Settings, or do a new and reset (hold down OPT/ALT and choose File>New & Reset All
~/archiben
b e n f r o s t
mm.. ok..any idea how to import fills from another file? i usually use merge then delete the "merged project" and i have the fills and materials..etc..
but for sure there is sometihng more advanced !!
Attribute manager.
__archiben
Options>Attribute Manager... - open the file you're wanting to steal from in the right-hand well, select the attributes that you want to transfer to your existing file, then 'Append'.
~/archiben
b e n f r o s t
Never used that i will start today..."stealing" stuff will be easier!!
MAN!! you people ROCK!!!!!
thanx
