‎2010-01-11 04:20 PM
‎2010-01-11 06:10 PM
‎2010-01-11 08:50 PM
Shelman wrote:Try OBJECTiVE. It works just like ArchiCAD's 2D rotate, but provides full 3D rotation (including objects in a section/elevation window). You can also rotate a selection of multiple objects about a common axis, something which is really hard to do on an object-by-object basis.
Hi. I need to rotate some Objects in x,y,z but in Archi, i just find rotating in X or Y. How could i rotate in X,Y,Z?!!
‎2010-01-12 01:02 AM
laszlonagy wrote:Tanks of your greeting and Sorry because of my bad English.
Welcome to the Forum,
Download and use the Rotator.gsm object found in the Object Depository:
http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/Archicad%20Modules
‎2010-01-12 01:46 AM
‎2010-01-12 10:51 AM
‎2010-01-13 12:30 AM
‎2010-01-13 02:13 AM
Shelman wrote:over all of those columns? you could try the mesh tool, then use the mesh to roof add-on
i need to cover that curve column by a smooth surface . how could i make it easy and fast ?
‎2010-01-13 03:50 AM
‎2010-01-13 03:51 AM
Matthew wrote:So that is what women on your planet look like.
That building appears to be in the shape of a supine woman. Is that allowed over there?
