Who to 3D Rotate? Please Help
Hi. I need to rotate some Objects in x,y,z but in Archi, i just find rotating in X or Y. How could i rotate in X,Y,Z?!!
13 Replies 13
Welcome to the Forum,
Download and use the Rotator.gsm object found in the Object Depository:
http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/Archicad%20Modules
Ralph Wessel
Try OBJECTiVE. It works just like ArchiCAD's 2D rotate, but provides full 3D rotation (including objects in a section/elevation window). You can also rotate a selection of multiple objects about a common axis, something which is really hard to do on an object-by-object basis.
Ralph Wessel BArch
Central Innovation
Tanks of your greeting and Sorry because of my bad English.
i need to rotate some object and pule it up to sky like a sliding board.
and also i need to cover some carve objects by a surface.
if im not clear pleas tel me to send you some picture of my works.
if i can find this thinks in the help pleas tel me what is the key word for searching in the help menu
by the way tanks of your helping .
who dose it works ?!!
I have not used the Rotator object myself, maybe someone who did can help you with it.
Yes, a screenshot of what you are trying to do always helps.
i need to cover that curve column by a smooth surface . how could i make it easy and fast ?
over all of those columns? you could try the mesh tool, then use the mesh to roof add-on
That building appears to be in the shape of a supine woman. Is that allowed over there?
Dwight
So that is what women on your planet look like.
Dwight Atkinson
