Who to 3D Rotate? Please Help
Hi. I need to rotate some Objects in x,y,z but in Archi, i just find rotating in X or Y. How could i rotate in X,Y,Z?!!
13 REPLIES 13
Dwight wrote:
Matthew wrote:
That building appears to be in the shape of a supine woman. Is that allowed over there?
So that is what women on your planet look like.
Just the ones in the shape of buildings.
well, its a swimmer and of curse its a man.
mesh is hard to use and need much time.
i could movie it to the 3ds Max, but all my objects are moveing to 0.0.0 direction.
what can i do to stop this disaster
Shelman wrote:
i need to cover that curve column by a smooth surface . how could i make it easy and fast ?
Again, try OBJECTiVE for this exercise. If you refer to the attached image, you can create profiles that can be rotated, bent, twisted, and cut to complex complex forms. Note that same can be done with the bundled steel objects - the beams have been bent to the roof curve and twisted in cross-section to follow the building profile. I can provide more detailed instructions if you're interested.
Ralph Wessel BArch
Central Innovation
