Why Dimentions are static in Int. Elevation?
Do you know why all kinds of Dimentions are static in Int. Elevation?
Every time I move an element in plan I have to go t each InteriorElevation view, delete the old Dimentions and make new ones!
16 Replies 16
vistasp
Mentor
Rod wrote:
Vistasp, how did you translate from German?
Did you use a translator and if so what is the name of the software?
Or do you speak German too
Hi Rod,
Unfortunately I don't know German so I rely on the Foxlingo plugin for Firefox. I say unfortunately because there seems to be a huge amount of GDL content in German. My wife does know a bit of it (German, not GDL) but the CAD stuff really throws her.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
ztaskai
Graphisoft Alumni
Graphisoft Alumni
vistasp wrote:
Unfortunately I don't know German...
We have something in English and Hungarian, too.
English: sections 3.5 and 3.6 of Technical Standards: http://www.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/12/LibDevGuid...
Hungarian: stuff I teach at the university from: http://docs.google.com/Doc?id=dg4s9hvs_3g32zqzfs
I can change both if you have any additions.
Regards,
Zsolt
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
Rod Jurich
vistasp wrote:
/..... so I rely on the Foxlingo plugin for Firefox./.....
Cheers Vistasp, I'll d'load the plugin.
Just marvellous, many thanks Vistasp
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
vistasp
Mentor
Thanks for the links, Zsolt. Is there an offline (PDF) version of the devguide available? One problem (that's been discussed on this forum before) is that the sources of information are so widespread, one often doesn't know where to look.
I'm struggling with the Hungarian page - Foxlingo failed spectacularly with it.
= v i s t a s p =
bT Square Peg
Here I post the result ov my work, which was why I started this thread! Thank you once again, guys! I would have given up wihthout your help!
ztaskai
Graphisoft Alumni
Graphisoft Alumni
I'm struggling with the Hungarian page - Foxlingo failed spectacularly with it. 😞
You can download the whole Basic Library (macros, samples and documentation) as a small ZIP file from http://www.graphisoft.com/support/developer/downloads/
Unfortunately, this version is updated less often than the solo HTML files.
The Hungarian description is for a minority, I know. The ratio of Hungarian speakers is 1:425 in the world but I guess it is around 1:100 in the GDL developer community 😉
Zsolt
Zsolt Táskai
vistasp
Mentor
Oops! I should have seen that. Thanks again Zsolt.
= v i s t a s p =
bT Square Peg
